1996 Ford Taurus
ZANEW.
  • 1996 FORD TAURUS
Smells problem
1996 Ford Taurus Automatic
the sales rep at autozone said your supposed to change oils every few thousand miles. My manual says I should use SAE 5W-30 but he said I needed 10W. Ever since I did the change it kinda smells like my block is burning up, anyone know anything about this changing oils thing?
Monday, June 15th, 2009 AT 6:21 PM
  • 109,885 POSTS
If the manual says 5W30, follow it. If you look in the manual, 10W30 may be an option in hot climates, but I recommend using the 5W30 if that is what it calls for. The reason fir it is to get oil throughout the engine faster on cold starts. 5-30 stays thinner than 10-30.
If you have other questions, let me know.
Thursday, June 18th, 2009 AT 10:38 PM
