2000 Ford Taurus water leaking inside - passanger side floo
13,000 MILES • 6 CYL • 2WD • AUTOMATIC
R1D2G3
I am suspecting a clogged roof drain. I would like to fix this myself, but do not know where the drains begin and end. The other likely suspect is the pollen filter - my spouse had this changed at last oil change. I have read on other car related blogs that the surrounding housing/seal on this filter can cause water to leak inside the car.
Help
May 3, 2009 at 2:54 AM
R1D2G3
I think I have this fixed. A big rain storm will surely tell, but the hose could test passed !! Dry.
When my spouse let one of those instant oil change places replace the pollen filter, they did not put the housing back on tight. I tighten that up and the water seems to be draining apprpriately.
May 5, 2009 at 12:09 PM
