1998 Ford Taurus engen locked up
BENARD123
  • 1998 FORD TAURUS
Engine Mechanical problem
1998 Ford Taurus 6 cyl Two Wheel Drive Manual
i was wondering why your moter would lock up when I just had the oil changed last week.
Sunday, November 29th, 2009 AT 3:01 PM
  • 31,937 POSTS
HI there,
has his been a hydraulic lock? Is a cylinder full of water? Pull the plugs and try and turn the engine over. Just don't have anyone stand in front of the engine as if it is water it will be ejected with great force. Otherwise it may be seized due to an oil problem or a mechanical failure, this will have to be check out first hand.
Mark (mhpautos)
Sunday, November 29th, 2009 AT 3:16 PM
BENARD123
  • 6 POSTS
The moter will start but the belt wont turn an you get a burning smell.
Sunday, November 29th, 2009 AT 3:35 PM
BENARD123
  • 6 POSTS
  • 31,937 POSTS
Something on the accessory drive has failed, idler pulley, A/C alternator? You will have to remove the belt and check to see what has locked up.
Mark (mhpautos)
Sunday, November 29th, 2009 AT 4:20 PM
