1995 Ford Taurus Timing Chain
JANIE5650
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 152,926 MILES
When do you change the timing chain/belt in a 1995 ford taurus?
Is it necessary to change the chaing/belt?
Monday, March 8th, 2010 AT 7:34 PM
BMRFIXIT
  • 19,053 POSTS
No set time or schedule maintenance for timing chain
Monday, March 8th, 2010 AT 7:38 PM
BILLYMAC
  • 2,204 POSTS
Hi
Well the timing chain your car has is not like a belt to change this part is a pretty major deal. Most people don, t until they break and the car doesn;t run.
But if you just want the satisfaction of knowing it has been changed then 100 thousand would be a good time. However when these things break they don, t do the damage, that you;ve prob have happen to overhead cam engines.
So I wouldn, t worry about it when it gets bad it will rattle usually before it breaks. Ty BillyMac
Monday, March 8th, 2010 AT 7:42 PM
