1995 Ford Taurus emergency brakes won't release
1995 FORD TAURUS
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JIM BARNER
how do I get these to release. Pulled on the release handle but nothing happens. Haven't used this for a long time. car is having prblms. brake light is on.
Apr 2, 2010 at 7:33 AM
  • 110,240 POSTS
The most common cause of a sticking parking brake is the final cables that go into the drum assembly. They rust and get stuck. It usually is the result of not using the park brake. As a result, it corrodes, rusts, and this happens. If you can lift the rear of the car safely, check to see if it is both cables or just one side. Try spraying the cable with penetrating fluid and working it to see if it comes loose. If it doesn, you will need to cut the cable as close to the drum as you can.
Let me know if it works.
Apr 5, 2021 at 5:33 AM
