Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Brakes
Symptoms
Pedal Goes to the Floor
2002 Ford Taurus brake pedal goes to the floor
2002 FORD TAURUS
120,000 MILES • 6 CYL • FWD • AUTOMATIC
JESSEJENNINGS
MEMBER
I have replaced master cylinder and Booster and have bled the brakes all the way around. No leaks I can see. Could this be the HCU?
Jun 22, 2010 at 1:19 PM
Experienced Mechanic
Recheck the master cylinder could be leaking internally though its new
Jun 22, 2010 at 1:26 PM
JESSEJENNINGS
MEMBER
Should I go back to Autozone and get it swapped out for a new one or is there a way to check the one I just bought?
Jun 22, 2010 at 1:32 PM
If you can do it go for it-If not bench test it
Jun 22, 2010 at 2:46 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
