1996 Ford Taurus Low Brake Pedal
250,000 MILES • 6 CYL • FWD • AUTOMATIC
WIZRD03
The brake pedal has recently gone low to actuate the brakes. It does not start high & sink like a bad maste cylinder would and it almost feels like stopping without power brakes. The brake fluid was replaced & brakes were bled several months ago after replacing the pads by vacuum bleeding at each cylinder until new, clear fluid with no air was visible in the bleeder hose. Bad master cylinder or power booster? There is a bit of side pull when appling the brakes now.
Jan 20, 2008 at 3:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d643fd5c5a="wizrd03"]Brakes problem
1996 Ford Taurus 6 cyl Front Wheel Drive Automatic 250000 miles
The brake pedal has recently gone low to actuate the brakes. It does not start high & sink like a bad maste cylinder would and it almost feels like stopping without power brakes. The brake fluid was replaced & brakes were bled several months ago after replacing the pads by vacuum bleeding at each cylinder until new, clear fluid with no air was visible in the bleeder hose. Bad master cylinder or power booster? There is a bit of side pull when appling the brakes now.[/quote:d643fd5c5a]
check rear brakes (clean and adjust )
check vacuum line at the booster
do you have brake light coming on
Jan 20, 2008 at 11:19 AM
WIZRD03
Turns out it was a very simple solution... Power bleed the brakes. It was just odd that it came on very suddenly, within a week from a high firm pedal to a low soft pedal.
Feb 7, 2008 at 3:11 PM
