HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Climate Control
Heater
Not Working
1994 Ford Taurus No heat and overheating
DOUG BAKER
MEMBER
1994 FORD TAURUS
6 CYL
FWD
AUTOMATIC
152,000 MILES
No heat and temp. Gauge steadily increases.
Thursday, December 27th, 2007 AT 6:12 PM
BLACKOP555
MECHANIC
Sounds to me that you should change your thermostat first.
SPONSORED LINKS
Thursday, December 27th, 2007 AT 6:55 PM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
1994 Ford Taurus Overheating And No Heater
At Random This Taurus Engine Temperature Will Spike And The Heater Will Start Blowing Cold Air. I Cannot Get It To Do It With Any...
Asked by
saylito
1994
FORD TAURUS
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
1994 Ford Taurus No Heat
I Have No Or Very Little Heat I Replaced The Heater Core Thermostat Flushed The System The A/c Workes Fine But The Heat Will Not Work If My...
Asked by
WISCONSIN
1994
FORD TAURUS
My Car Heater Is Not Working Why?
Today I Noticed That When I Turn The Heat On But It Is Still Cold Why?
Asked by
dvaughn1
37 IMAGES
2010
FORD TAURUS
2002 Ford Taurus Very Little Heat
Heater Problem 2002 Ford Taurus 6 Cyl Two Wheel Drive Automatic I Have Very Liitle Heat We Changed The Thermostat But That Wasn't It...
Asked by
dmdjf
2002
FORD TAURUS
A/c & Heater Not Working Properly!
Well This Problem Has Been Going On Since Winter. I Have A V6 2000 Taurus, 120,000 Miles, Automatic And In The Wintertime The Heat Blows...
Asked by
transam85tpi
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Heater Not Working
Blend Door Actuator Replacement
How to Replace Damper Door Switch
Online car repair manuals
