1995 Ford Taurus Coolant not circulating, no heat
JONNFERRELL
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 46,000 MILES
Car had episode of coolant loss and overheat. Car has very little heat--barely warm at best. Fluid in reservior is cold after long drive, nothing seemed to be circulating. I replaced thermostat after overheat. Still no heat and temp gauge does not move, stays on the lowest possible (I'm not sure where the sensor is, my grand am was in the reservoir, so if the Taurus is, then it's no wonder it's low).
Took to dealer, they replaced the thermostat--and the other was only a week old. Gauge is still on cold, heat is still only warm, reservoir is still cold. Took back and had them look at it--they looked very confused. Does not seem to be a head gasket at this time. Any ideas? If it turns out to be a head gasket--how much do you think?
Thursday, December 13th, 2007 AT 6:12 PM
LEGITIMATE007
  • 5,121 POSTS
You may have to bleed the coolant system. Sometimes when you fill a radiator it will create air pockets because there is no where for the air to go.
Thus making it impossible for the fluid to go where it needs to.
Friday, December 14th, 2007 AT 10:06 AM
LEGITIMATE007
  • 5,121 POSTS
Head gaskets are quite expensive.7, 8 900 dollars and more. Sorry man
Friday, December 14th, 2007 AT 10:07 AM
