1994 Ford Taurus 1994 Ford Taurus electriacal problems with
MRYANHOCKEY87
  • 1994 FORD TAURUS
  • 6 CYL
  • FWD
  • 189,000 MILES
My 1994 ford taurus has had a fuel problem in last couple of weeks; I replaced the fuel filter, checked the pump which was in good condition even though I have had a problem. I know its not the pump, the filter, I checked the IRCM model J and the pump work when I positve jump on the alternator and the pin for the fuel pump. Know my question is where is the fuel pump relay and the droping resistor; and the inerta switch I have checked but I cant find the problem their.
thanks
Friday, August 13th, 2010 AT 9:38 PM
Hi mryanhockey87, welcome to 2carpros and TY for the donation
What liter -3.0 or 3.8L?
When you applied direct power to the fuel pump this will cause the engine to fire up unless the injectors are not pulsing or its not getting an ignition spark-
Although the new fuel pump comes on, the question here-is it producing the correct fuel pressure, you need to check the actual fuel pressue if its within specs
Friday, August 13th, 2010 AT 11:18 PM
MRYANHOCKEY87
Thank you for your input.
Know I also checked the resistance to the injectors and didnt give me a reading on two of them facing in front of the engine. Also where is the relay? And if the pressure is a problem my option would be changing the regulator near the manifold, right?
Saturday, August 14th, 2010 AT 9:07 AM
The fuel pump relay is integrated within the constant control relay module on upper radiator support. You need to check the fuel pressure with a gauge to rule out the fuel filter, fuel pressure regulator and fuel pump
Saturday, August 14th, 2010 AT 2:44 PM
