1993 Ford Taurus oil pressure
SLIMEPIG
Engine Mechanical problem
1993 Ford Taurus 6 cyl Front Wheel Drive Automatic 173k miles
oil pressure drops and idiot light comes on when I reach highway speed. I pull off the road , turn off car. after 15-20 seconds, i restart car and the oil pressure returns and engine ticks smooth out. then does same again when i return to highway speed. oil level is full, or in normal range.
Nov 13, 2009 at 3:47 AM
BMRFIXIT
  • 19,053 POSTS
If the drop of oil pressure comes with an engine ticking
I would suspect and have the oil pump replaced
if all normal no sound from the engine replace oil pressure switch
Nov 13, 2009 at 11:37 AM
