Hi there,
Thank you for the donation,
The transmission will not have any bearing on the coolant loss, first get the cooling system pressure tested as this will locate any external coolant leaks, as for the trans, I would not be doing another flush as it is not going to achieve any positive results so soon after the last one, just have a qualified mechanic, inspect and report on the engine & transmission leaks, they will advise you on the best action for this after they have inspected them.
Mark (mhpautos)
SPONSORED LINKS
Saturday, August 29th, 2009 AT 10:47 PM
