2000 Ford Taurus Leaking radiator
2000 FORD TAURUS
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
CTF
My 2000 Ford Taurus does not have a radiator cap on top just a resevoir. Can i put some stop leak in the over flow or resevoir? If I can what is the best stop leak to use? I just need a temporary fix until after Christmas. Thanks
Dec 2, 2008 at 7:36 AM
BMRFIXIT
  • 19,053 POSTS
Sealer is not recommended
(yes if to add it goes in the side over flow )
it does more harm than good
if you can do with out will be a better choice
replace the radiator
good luck
Dec 2, 2008 at 9:33 AM
