1991 Ford Taurus Failed Emissions
If want to read the trouble codes for your car you will need to buy a code scanner. They range in price from $50 and up depending on the make and model of the scanner. When purchasing one make sure it is for OBD II for this is the system your car uses. To use the scanner follow the instructions that come with it. A good one will have a screen that displays the directions as you use it in a step by step manner. The scanner gets connected to a plug in connection usually located under the dash on the drivers side. FYI this tool is a great help in trouble shooting your engine management system but don't be confused and think it will fix the problem. It will only lead you in the right direction. Once you know what the problem is you will still need to change the defective piece.
Good luck :) Backyardmechanic
Suggested Repair
Use an OBD-I code scanner; the diagnostic connector may be under the hood or under the dash. The scanner only identifies faults and does not fix them. For the emissions failure, confirm the oil is clean and the correct grade, verify the cooling system is working properly, and consider replacing the PCV valve.
Conversation Summary
The owner of a 1991 Ford Taurus wagon failed an emissions test for hydrocarbons and oxides of nitrogen after an oil and air-filter change. Replacing the oxygen sensor nearly improved hydrocarbons but made NOx worse, and the car otherwise runs well. The expert first recommended an OBD-II scanner, then corrected that a 1991 uses OBD-I and needs a compatible scanner connected under the hood or dash. For emissions, the expert suggested correct clean oil, a properly working cooling system, and a possible PCV valve replacement.
