2003 Ford Ranger Voltage Gauge Drops
MANDABEAR
2003 Ford Ranger XLT 57,000 Miles. Back in June I had to replace my battery when I came back from out of town and could not get home from a friends house. Now when I have my headlights, running lights, and my heater on my battery gauge drops to low. At times when I am driving it will move back to the center while I am pressing on the gas petal and when I slow down and lift off the gas it drops again. I have not had this problem in the past and I have had the alternator checked and the battery checked, along with the connectors..however I am still told there is no issue with my truck...is this normal and nothing to worry about or is there another underlying problem that may be causing this? Any help would be great!!!
Jan 19, 2007 at 8:52 AM
  • 75,988 POSTS
[quote:ce532a414f="MandaBear"]2003 Ford Ranger XLT 57,000 Miles. Back in June I had to replace my battery when I came back from out of town and could not get home from a friends house. Now when I have my headlights, running lights, and my heater on my battery gauge drops to low. At times when I am driving it will move back to the center while I am pressing on the gas petal and when I slow down and lift off the gas it drops again. I have not had this problem in the past and I have had the alternator checked and the battery checked, along with the connectors..however I am still told there is no issue with my truck...is this normal and nothing to worry about or is there another underlying problem that may be causing this? Any help would be great!!![/quote:ce532a414f]
Correct size battery? It needs another charging system check-maybe the limiter is going whack!
Jan 19, 2007 at 4:30 PM
Suggested Repair
Confirm the battery is the correct size and rating, then have the charging system checked again, including the voltage limiter or regulator, which may be failing.
Conversation Summary
The owner of a 2003 Ford Ranger says the battery gauge drops low with the headlights, running lights, and heater on, then rises while accelerating and drops again when slowing. The battery was recently replaced, and the alternator, battery, and connectors were checked and reported fine. The expert suggests verifying the correct battery and rechecking the charging system, possibly for a failing voltage limiter.
