1998 Ford Ranger Turn Signals Dead
ERIC15
I have a 98 ranger with 140,000 miles on it. It is the 4 cylinder. My problem is one day after hooking a boat up my turn signals quit working. First thought would be check the fuses. But I did and all seem to be in working order. So where do I go next? Thanks
Sep 12, 2007 at 9:01 AM
  • 31,937 POSTS
Hi there,
Do the dash indicator lights illuminate when you operate turn signal? If they do but don't flash i would be looking at replacing the flasher can, that's the electronic control that make the indicators blink on and off, the trailer wiring may have damaged this unit, Now i am not sure where the flasher can is located on your car as we don't have that vehicle here in Aus. So best ask your local mechanic where it is located and that may fix your problem.
Mark (mhpautos)
Sep 12, 2007 at 6:24 PM
ERIC15
I'm getting nothing when I try to use my turn signals. Nothing at all on the dash lights up.
[quote:d36de29f7c="mhpautos"]Hi there,
Mark (mhpautos)[/quote:d36de29f7c]
Sep 13, 2007 at 1:14 AM
  • 31,937 POSTS
Hi there,
Make sure that the fuse is OK, check that voltage is flowing thorough it, if OK, check the flasher can. The indicator switch is normally robust enough to cope with a faulty trailer wiring fault, but don't disregard it totally.
mark (mhpautos)
Sep 13, 2007 at 12:36 PM
Suggested Repair
Confirm the turn-signal fuse is good and has voltage through it. If it does, check or replace the flasher unit, which trailer wiring may have damaged. Do not rule out the turn-signal switch if those checks do not restore the signals.
Conversation Summary
The owner of a 1998 Ford Ranger said the turn signals stopped working after connecting a boat trailer. The fuses appeared intact, and later the owner reported that the dash indicators did not light at all. The expert advised verifying voltage through the fuse, then checking the flasher unit, while also not completely ruling out the turn-signal switch.
