2002 Ford Ranger Alternator Install Fix
TIMANUS.V
How to install an alternator in an 2002 Ford Ranger?
Jan 1, 2007 at 2:12 PM
GARFIELD
  • 197 POSTS
First step would be to disconnect the negative lead on the battery. Remove the belt, disconnect the electrical connections on the alternator(normally a bolted wire and a plastic connector). Then remove the mounting bolts holding the alternator to the mounting bracket/engine. The installation is just reversing what you have already done.
Jan 1, 2007 at 10:32 PM
Suggested Repair
Disconnect the battery negative cable, remove the drive belt, unplug the alternator wiring (bolted lead and plastic connector), and remove the mounting bolts. Install the replacement by reversing those steps.
Conversation Summary
The owner asked how to install an alternator on a 2002 Ford Ranger. The expert advised disconnecting the negative battery cable, removing the belt and electrical connections, unbolting the alternator, and reversing the process for installation.
