2002 Ford Ranger Shifting Trouble
OHDONNY
I have a 2002 Ford Ranger Manual Transmission. It has just under 100,000 kms on it and lately I have been having trouble shifting (even with the clutch to the floor, I cant get it into gear). I'm not to familiar with trucks, but the fluid levels seem to be good and I just had the truck tuned up and checked over a few months ago and all was well.....at that time. As well, this problem comes and goes. sometimes when I drive it, the clutching is normal....but I'll turn the truck off for 5 mins. and when i drive it again, it will give me troubles. any tips would be appreciated!
Apr 10, 2007 at 1:45 PM
SERVICE WRITER
  • 9,123 POSTS
Pull off the cap for the master cylinder for the clutch. It is a small round one, not to be confused with the Brake master cylinder. Be sure that fluid level is good. You may have a bad slave cylinder regardless.
Tranny would have to come out (ouch).
Apr 10, 2007 at 1:55 PM
Suggested Repair
Check the clutch master cylinder fluid level in the small round reservoir, not the brake master cylinder. A failing clutch slave cylinder is possible and typically requires transmission removal to replace.
Conversation Summary
The owner of a 2002 Ford Ranger with a manual transmission reports intermittent trouble shifting into gear even with the clutch fully depressed, despite apparently good fluid levels. The expert advises checking the clutch master cylinder fluid and suspects a bad slave cylinder, which would require removing the transmission.
