check engine light is on code p0401 remove code with scan tool but light will return on again what shall i do next please help
May 18, 2007 at 8:28 AM
Because P0401 returns after clearing, inspect the EGR valve and solenoid and check the related wiring harness for faults.
The owner reported a Ford Ranger service engine soon light with code P0401 that returns after being cleared with a scan tool. Replies in the thread also discuss an unrelated ABS/CV axle issue and a 1998 Saturn SW1 with the same code. The relevant advice is to check the EGR valve or solenoid and its wiring harness.
