1991 Ford Ranger Hard Shift
NYC74
1991 Ford Ranger xlt, 3.0l V6, 66,000 miles. It's a little difficult to shift into 3rd and sometimes 1st gear, especially after warming up in too much stop-and-go city traffic. Clutch does not slip, just some resistance getting into gear. Clutch fluid level looks ok, but the fluid looks very muddy. This truck is a Hurricane Katrina survivor, and I'm not sure how 'wet' exactly it got, but there are problems with brake hydraulics too.
May 12, 2006 at 5:20 AM
LOSONE
  • 1,616 POSTS
I live in Biloxi, so I know all about Katrina.
You have either a bad clutch master cyl or a bad slave cyl. Another good move by Ford, they put the slave cyl inside the transmission housing and you must remove the tranny to replace it. Good luck
May 12, 2006 at 5:47 AM
Suggested Repair
Inspect and replace the clutch master cylinder or slave cylinder as needed. The slave cylinder is inside the transmission housing, so the transmission must be removed to replace it. Also address the muddy clutch fluid and related hydraulic issues.
Conversation Summary
A 1991 Ford Ranger with 66,000 miles is hard to shift into 3rd and sometimes 1st, especially after warming up in stop-and-go traffic. The clutch does not slip, but the fluid looks muddy, and the truck also has brake hydraulic problems after Hurricane Katrina. The expert says the clutch master cylinder or slave cylinder is bad, and notes that the slave cylinder is inside the transmission and requires transmission removal to replace.
