2000 Ford Ranger Won't Restart
You can have fuel in the rail but does it have the correct fuel pressure. Get the fuel system squared away before you get to the ignition.
Remember fuel comes before ignition
48 lbs fuel pressure with key on....however it falls off very quickly....58 lbs when engine is cranking....neighbor added a few drops of fuel to intake and the engine tried to fire....seems like fuel problem to me too. There is 13 volts at the injectors.
The kid at the parts store said that the valves got fried since we ran it without the pipes tight....seems like a stretch to me.
This is making me nuts......thanks for the help!!!!!
This is making me nuts......thanks for the help!!!!![/quote:bbd8a36273]
On EFI-equipped engines, fuel pressure in the line does not necessarily mean the fuel is being injected into the engine. Listen for clicking or buzzing that would indicate the injectors are working. No noise? Check for voltage and ground at the injectors. A defective ECM may not be driving the injectors, or the EFI power supply relay may have called it quits. Some EFI-systems rely on input from the camshaft position sensor to generate the injector pulses. Loss of this signal could prevent the system from functioning.
Next agenda will be Valve timing/Compression
Good Luck-don't go wacko it ain't over till I play ( You keep me hanging on) by Vanilla Fudge.
Suggested Repair
Confirm the fuel system holds pressure and that the injectors are actually firing. Listen for injector click or buzz, and check voltage and ground at the injectors. If there is no pulse, test the EFI power relay, ECM injector drive, and camshaft position sensor signal. If fuel delivery checks out, move on to valve timing and compression.
Conversation Summary
A 2000 Ford Ranger 3.0 flex-fuel started after an engine swap, ran to normal temperature, then would not restart after the exhaust bolts were tightened. The owner reported spark, fuel at the rail, a new filter and plugs, secure grounds, and good cranking. Pressure was about 48 psi key-on but dropped quickly, and about 58 psi while cranking; a small amount of fuel in the intake made it try to fire, and the injectors had 13 volts. The expert said rail pressure does not prove fuel is being injected and advised checking injector operation, injector voltage and ground, the ECM and EFI relay, and camshaft position sensor input, then valve timing and compression.
