the fuel gauge on my 1986 ford ranger does not work, how do i make it work?
Feb 24, 2006 at 7:30 AM
Check the fuel sending unit on top of the tank. In moderate winter climates, rusted ground and power contacts can stop the gauge. If that is not the cause, try exciting the gauge.
The owner reports that the fuel gauge on a 1986 Ford Ranger does not work and asks how to fix it. The expert says the sending unit on top of the tank is the likely cause, noting that ground and power contacts can rust in moderate winter areas and stop the gauge. If that is not the problem, the expert suggests trying to excite the gauge.
