Ford Ranger 2001
AJBIHL
AC is not blowing cold air until it has been running for 15-30 minutes (it varies with no predictability).
I took it to the shop, and the compressor appears not to be running, then will start after a period of time.
They said it was an "electrical problem" and they would just have to start running tests to find it.
True? or not?
Apr 19, 2007 at 8:30 AM
MERLIN2021
  • 17,250 POSTS
First thing to check is the state of the refrigeant charge. There is a low and high pressure sensor on the low and high side lines...I would check the low pressure sensor near the firewall. Unplug it then use a paperclip and cross the contacts on the connector. If it starts running and the R-134a is full, change the sensor.
Apr 19, 2007 at 8:33 AM
