1994 Ford Ranger Clutch Won't Engage
BOBWOL
i have replaced all of the parts for my 1994 ranger 4 liter 300000km,s clutch,new master cylinder,new slave cylinder,new clutch disc,new pressure plate. the problem is i still don't have a clutch. the slave cylinder dosen't move when the clutch pedal is depressed. any ideas that might fix this. :?:p.s.i have bleed the sytem and it has no air left in it.
Aug 5, 2007 at 3:49 PM
  • 31,937 POSTS
Hi there,
If every thing has been put back togeather as it should, the problem is air in the system. Now Clutch master cyl don't have a foot valve, so you can't pump up pressure like the brakes. Fill the system with brake fluid and have a friend help you bleed the system. Hold the pedal down, open the bleeded untill no more bubbles or air is expelled ( will only take a few seconds) and close bleeded Lift pedal and wait a few seconds so the pistin can retract and press down again, open bleeded and clear system, always make sure that the bleeder is closed before lifting pedal, as this will allow air back into the system, keep fluid topped up so air will not be drawn into system from master cyl and you should have a firm pedal in on time.
Mark (mhpautos)
May 4, 2021 at 3:44 AM
Suggested Repair
If the clutch is assembled correctly, bleed trapped air from the hydraulic system. Fill the master cylinder with brake fluid, hold the pedal down, open the bleeder until fluid with no bubbles comes out, then close it before releasing the pedal. Pause so the piston can retract, repeat, and keep the reservoir topped up so air is not drawn back in.
Conversation Summary
The owner of a 1994 Ford Ranger 4.0L replaced the clutch disc, pressure plate, master cylinder, and slave cylinder, but the slave still does not move when the pedal is pressed. The owner believes the system has already been bled. The expert says the clutch master has no foot valve, so it cannot be pumped like brakes, and recommends a two-person bleed with the pedal held down, the bleeder closed before the pedal is released, and the fluid kept full.
