2003 Ford Ranger XLT clutch and slave cylindar repair
2003 FORD RANGER
HAYTIM
Vehicle has approx 48K miles on it 4.0 liter 6 cylindar--I replaced the clutch and slave cylindar but the car will not go into gear. What's left to do or what did I miss?
Thanks for the help
Nov 12, 2007 at 12:34 AM
FAIRRACING31
  • 150 POSTS
Did you bleed the clutch system?
Nov 12, 2007 at 5:40 AM
HAYTIM
[quote:b736ffe93b="fairracing31"]Did you bleed the clutch system?[/quote:b736ffe93b]
Not yet, I know I have to do that. Is there anything else I should look for or do?
Nov 12, 2007 at 6:33 AM
FAIRRACING31
  • 150 POSTS
If you installed your clutch properly, you should be okay after bleeding the system.
Under Ford Ranger repair: 1993 ford ranger by gwsadle. I give step by step on how to bleed the clutch on Ranger 1993-2005.
Nov 12, 2007 at 7:06 AM
