I depressed the clutch there was a kind of a pop noise
KEEFER50
The clutch went out. When I depressed the clutch there was a kind of a pop noise then the compression decreased to about half of what it normally is but I was still able to change gears although the clutch engaged much sooner then usual. 8 hours later there was no compression at all and the only way to get it in gear was the turn off the engine and start the engine in gear. What is the fix for this?
Nov 3, 2007 at 5:48 AM
MERLIN2021
  • 17,250 POSTS
Have you checked the slave cylinder on the tranny for leaks? or the line...
May 4, 2021 at 3:44 AM
MERLIN2021
  • 17,250 POSTS
Inbox :: Message From: keefer50 To: merlin2021 Posted: Sat Nov 03, 2007 10:52 pm Subject: slave cylinder your replied to my original question about my clutch that went out - you said to check the slave cylinder - which I did and it looks like it is where the clutch fluid is leaking to. What is involved in replacing the slave cylinder? Does the transmission need to be taken off? Is it an easy fix? Thanks very much for responding!! Yes the tranny needs to be out to replace the slave...
https://images.2carpros.com/forum/automotive_pictures/62217_Slave_copy_1.jpg
