1995 Ford Ranger clutch
GROM01
Transmission problem
1995 Ford Ranger Two Wheel Drive Manual 145000 miles
My clutch worked fine driving home from work. When I went to get back in it the next day, when I started it, the truck started to take off on its now. and now I have NO pressure in the clutch pedal when pressing it down. What can cause this? Clutch had plenty of pressure before and now none. Went into gears just fine without any grinding. I've got no idea. and I have no idea how to replace it myself.
Dec 1, 2007 at 6:17 AM
FSTRANGER302
  • 117 POSTS
[quote:616dc93597="Grom01"]Transmission problem
My clutch worked fine driving home from work. When I went to get back in it the next day, when I started it, the truck started to take off on its now. and now I have NO pressure in the clutch pedal when pressing it down. What can cause this? Clutch had plenty of pressure before and now none. Went into gears just fine without any grinding. I've got no idea. and I have no idea how to replace it myself.[/quote:616dc93597] hello, try to pump clutch pedal and see if the pedal starts to work. also check slave cylinder resivor. under the hood drivers side by hood hinge. if it empty fill and pump may have to bleed it hope it helps let me know pat
Dec 5, 2007 at 3:44 AM
  • 55,649 POSTS
This happens when the secondary cylinder goes out which is common, look under the transmission bellhousing and there should be a leak and if so this video will show you howe to fix it. The video is on a similar car but the process is the same.
https://youtu.be/JpzefqEeVGE?si=e5QhrtTtfyxwig7y
Please go over this guide and get back to us.
Jun 25, 2024 at 8:11 AM
