1990 Ford Ranger Antifreeze Leak
OLIVER
I have a 1990 ford ranger (4.7 245000mi. vin#1ftcr10x7luc08475) and is leaking antifreeze from the bottom of the motor, but is not running hot. What could the problem be?
Jun 20, 2007 at 7:24 AM
BOOTDOG
  • 665 POSTS
it could be a number of things. a hose, water pump, freeze plugs just to name a few. you'll need to find the leak before it gets worse and repair the problem before the motor does overheat.
Jun 20, 2007 at 8:59 AM
Suggested Repair
Locate the coolant leak before it worsens. Possible sources include a hose, the water pump, or freeze plugs; repair the source so the engine does not overheat.
Conversation Summary
The owner of a 1990 Ford Ranger reports antifreeze leaking from the bottom of the engine, though the engine is not running hot. The expert says the leak could come from a hose, water pump, or freeze plugs, and advises finding and repairing it before the engine overheats.
