atifreeze leak
OLIVER
I have a 1990 ford ranger (4.7 245000mi. vin#1ftcr10x7luc08475) and is leaking antifreeze from the bottom of the motor, but is not running hot. What could the problem be?
Jun 20, 2007 at 7:24 AM
BOOTDOG
  • 665 POSTS
it could be a number of things. a hose, water pump, freeze plugs just to name a few. you'll need to find the leak before it gets worse and repair the problem before the motor does overheat.
Jun 20, 2007 at 8:59 AM
