Swap Engine
MASTERTECHTIM
  • 4,750 POSTS
Leave transmission in car. If installing standard on a engine that had a automatic the only thing you have to do is use the flywheel from the standard motor and you will have to install a pilot bearing into the crankshaft of the new engine. Hope this helps
Monday, January 13th, 2020 AT 10:53 AM (Merged)
JASON SNYDER
  • 2002 FORD RANGER
  • 3.0L
  • 6 CYL
  • 160,000 MILES
It looks like there haven't been any changes to the block from 1993 to 2002?
Thanks!
Monday, January 13th, 2020 AT 10:54 AM (Merged)
  • 52,797 POSTS
Good afternoon,
Correct. The basic blocks are the same. It is the add ons that are different for each application.
