One way to check the fuel pump is to locate the fuel pump relay in the underhood fuse block. Using a test light find the 2 hot sockets then using one of them take a jumper wire and place one end in a hot socket and the other end in one of the sockets that are not hot. Once you jump the correct socket the pump will turn on as long as pump is working. If you don't hear the pump turn on then most likely your pump is bad.
Saturday, July 5th, 2008 AT 10:34 PM
