2003 Ford Ranger fuel pump?
40,000 MILES • 6 CYL • 2WD • MANUAL
EVAN_1704
i own a 2003 ranger 3.0 and i have replaced the fuel pump three times in the last two months. the truck will run fine for a week or two then the fuel pump goes bad. i have also replaced the fuel pump relay,and fuel filter.....what else could be burning up the fuel pumps like this?
Jan 21, 2008 at 3:54 AM
  • 75,988 POSTS
Check the voltage on the fuel pump, fuel pressure regulator and restriction in the lines.
Jan 21, 2008 at 7:27 AM
