2003 Ford Ranger 4WD Lurch
Are talking about when your turning or straight or both?
What speeds do you engage it?
Are you in "high" or "low"
I have a 98, I don't know if a vacuum loss will affect this for anything other than engaging or disengaging, but the two vacuum lines at the front wheel corrode and allow a leak. A slight lurch is maybe normal, but i couldn't engage/disenge. I hope this may help.
Ps. I'm new to this site, and not sure about the whole donation thing. But, I'd be happy to do it.
There are certain speeds that you want to engege the 4-wd and speed you don't want to. Don't do it under 10 mph or over 50. It can't engage accuratley and it will slam in or slam out.
A weak vacuum will cause a partial engagement and slam. There is a vacuum line the goes to the wheel, follow it back to where it connects to a metal tube. Disconnect and clean this tube with enery cloth, and try to clean the vacuum line if anything crusty is in there with a pipe cleaner or whatever you think of. LIGHTLY apply a small amount of silicone around the metal tube no closer than 1/4 " from the end, and reattach the vacuum line. This is where mine had a problem.
If problem is still happening, check the vacuum of the system for leakage.
Suggested Repair
Check the front-axle vacuum engagement system for leaks. Follow the vacuum line to the metal tube, clean corrosion from the tube with emery cloth and any crust from the hose, then lightly apply silicone no closer than 1/4 inch from the tube end and reconnect. If lurching continues, test the vacuum system for leakage. Engage 4WD only between about 10 and 50 mph so it does not slam in or out.
Conversation Summary
A 2003 Ford Ranger 4WD lurches or jerks in 4-high at any speed, on hills, flat ground, corners, and straight roads, and can lose traction; switching back to 2WD causes one jerk then normal operation. The transfer case was replaced under warranty after damaged splines, but the problem returned, and the owner suspects the control module while the dealer mentions tire wear. The expert says weak or leaking vacuum can cause partial engagement and slamming, recommends cleaning and resealing the front vacuum-line connection, checking the system for leaks, and engaging 4WD only between about 10 and 50 mph.
