99 Ford Ranger XLT 4WD problem
CHIMERIX
  • 1999 FORD F-150
I have a 99 Ranger XLT, 150K miles, v6 engine. I bought it second hand to take up some "unimproved" mountain paths. It has a tendency to not stay in 4wd.
One minute, I'm in 4w low, climbing in and out of erosion gullies with no effort. The next, my rear tires are spinning, and the front just sit there. According to the dash indicator light, I'm still in 4w low. I shift to neutral, switch into 2wd, then back into 4w low, and voila! Up she comes! Until the next time she doesn't.
No pattern I can recognize, no overt sign that the front wheels have stopped pulling until I stop moving.
Saturday, May 12th, 2007 AT 12:50 AM
BRUCE HUNT
  • 3,754 POSTS
Have the codes pulled and that should help point the right direction.
Friday, February 16th, 2007 AT 1:30 PM
BLASTERMAN808
  • 11 POSTS
I was told to pull the codes. There were two(2) codes: P0700 - trans control system malfunction & P1791 - don't have info on this code. Does anyone know what parts are affected by these codes. 1996 Acura Integra LS, 1.8 liter, auto trans, 181K Miles.
Monday, February 19th, 2007 AT 5:11 PM
BLASTERMAN808
  • 11 POSTS
Replaced the vss(vehicle speed sensor) for one of the codes. It didn't help.
Friday, March 9th, 2007 AT 12:31 AM
BLASTERMAN808
  • 11 POSTS
I double checked the wiring connectors on the auto transmission and two connectors were not in the correct location. I swapped the connectors and my problems went away. I hope this helps someone else with the same problems.
Thursday, March 22nd, 2007 AT 9:19 PM
BLACKOP555
  • 10,371 POSTS
Id have to say if it has automatic locking hubs its time to replace them with maual ones as auto's have a tendency to stop working after a bit.
Saturday, May 12th, 2007 AT 7:36 AM
