1998 Ford F-150 4 wheel drive
FORE
  • 1998 FORD F-150
  • V8
  • 4WD
  • 120,000 MILES
Hi, locked in low range 4 wheel drive, can't get it out?
HELP PLEASE!
Tuesday, August 24th, 2010 AT 2:32 PM
  • 109,885 POSTS
Do you have the electronic shift 4wd? Is so, have you checked to see if the actuator is getting power on the transfer case?
Tuesday, August 24th, 2010 AT 8:30 PM
FORE
  • 5 POSTS
Yes it is electionic, I checked the electric vacuum pump by disconnecting it, and operating the switch, its working fine but still stuck in low range 4 wheel drive. The lever works back and forth but still stuck?
Tuesday, August 24th, 2010 AT 9:45 PM
  • 109,885 POSTS
What lever? Does it have the push button 4wd or the lever on the floor?
Tuesday, August 24th, 2010 AT 10:59 PM
FORE
  • 5 POSTS
It has the dial switch on the dash. I would pay you so much more but down to my last dollar and will donate more later more I promise. Thanks man!
Tuesday, August 24th, 2010 AT 11:08 PM
  • 109,885 POSTS
Please don't worry about that. We are here to help. As far as the 4wd, there is a 4wd actuator on the transfer case. When you turn the knob, it sends power to the actuator. I need to know if you are getting power to that part when the knob is turned. It is not uncommon for them to go bad.
Wednesday, August 25th, 2010 AT 11:47 AM
FORE
  • 5 POSTS
Yes I am getting power. And thanks again so much.
Wednesday, August 25th, 2010 AT 2:04 PM
FORE
  • 5 POSTS
Still stuck! UGH!
Wednesday, August 25th, 2010 AT 7:32 PM
FORE
  • 5 POSTS
Hi guys, are you still there cause I am still stuck in 4 low. Been great so far and thanks again.
Friday, August 27th, 2010 AT 10:59 AM
