2001 Ford Ranger NO CODES
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
HILLHEAD
  • 8 POSTS
MY RANGER IDLES VERY ROUGH..AT 50 MPH IT MISFIRES AND LOSES POWER--ON THE DOWNSTREAM OXYGEN SENSOR MY SCANNER SHOWES "NO DATA" AND ITS A NEW SENSOR.. THE MAS,TPS, COIL, PLUGS,HAVE ALL BEEN REPLACED.. IT SHOULD BE SETTING 3 CODES BUT NO CODES ARE SET...IS IT A BAD POWER CONTROL MODULE?? ANY HELP WILL BE GREATLY APPRECIATED....
Mar 9, 2010 at 1:56 AM
HMAC300
  • 48,601 POSTS
for the rough idle try using some choke cleaner and clean the throttle plate on both sides, maiking sure to clean the iac area as well. the truck may start hard after doing this. Make sure to hook the air duct up properly as well. Then after you get it running put a vacuum guage on the truck and taek a reading. It should be 20" if it is around 15" your converter may bebad. Other than that you would need o check your crank sensor as theycan go bad and not show a code.
Mar 9, 2010 at 9:25 AM
HILLHEAD
  • 8 POSTS
HELLO--I HAVE 20 IN. VACCUM- CLEANED THROTTLE BOBY..NO CHANGE..WHAT I DONT UNDERSTAND IS THE "NO DATA FROM THE BANK 2 OX. SENSOR-- ITS NEW (THE ONE BEHIND THE CAT)..ALSO IT HAS A NEW M.A.S AND WHEN ITS UNPLUGGED, WHEN IDLING IT DOES NOT KILL THE ENGINE..AND STILL AT 50 MPH IT MISFIRES , NO POWER, AND NO CODES..
Mar 11, 2010 at 12:21 PM
HMAC300
  • 48,601 POSTS
if you unplug a sensor it won't kill the engine, it just goes into open loop that's a saafety feature. If you are getting no data from the one sensor, then there is a flow problem( possible cat converter) or the wires aren't sending through to the computer. Or the wires are grounded someplace. Before youreplace an item like a module have apro look at it as you've dumped a ton of money into it already and still not fixed the problem. ther may be a tech bulletin out that you don't have access to that tells how to fix the very thing you have wrong....
Mar 11, 2010 at 11:18 PM
