2000 XLT Ford Ranger 4 cyl-check engine, abs, airbag lgt on
RAYKNICELY
I recently ran off the road due to a tire blowout and encountered some rough terrain. Two days following that, my airbag light came, followed by the ABS, and then the check engine light - next the speedometer stopped working (it doesn't leave the 0).
The engine revs at stoplights (RPM gauge accelerates) engine usually stalls, but will start immeadiately after. What could be causing all these issues?
93675 miles
single cab
manual transmission
Aug 25, 2007 at 7:16 AM
04RANGER
well to start idk about the air bag light or too much about the off road time but the ,check engine,the ABS and the speedometer arent working because of one of the speed sensors.theres 2 on your truck,one is on the tranny and the other one is on the rear end axle on the top of the diff.,usually the one thats goes is the rear end one.i would try that one first.there also cheap,20 bucks usually.try it out and let me know.
Feb 16, 2008 at 1:59 PM
