2000 Ford Ranger Rough Idle/turns off when AC is on
BOURASSA
  • 2000 FORD RANGER
  • 4 CYL
  • MANUAL
  • 17,000 MILES
Truck idles rough. Runs a little better after warmed up. When the AC is on. The engine will turn off when you are stopped/clutch pushed in. As long as you are moving the AC can be on. This has happened before. But the symptoms go away after a day or two. It has been seven days with this problem.
Monday, June 14th, 2010 AT 10:05 AM
  • 109,885 POSTS
Has the check engine light come on? Have you checked for vacuum leaks?
Monday, June 14th, 2010 AT 11:25 AM
BOURASSA
No to both questions
Monday, June 14th, 2010 AT 10:55 PM
  • 109,885 POSTS
I would suggest checking for vacuum leaks. Also, I would suggest checking fuel pump pressure when it's cold. If you need instructions, let me know.
Wednesday, June 16th, 2010 AT 9:26 PM
BOURASSA
Yes,
Please provide instructions.
Thanks!
Wednesday, June 16th, 2010 AT 10:53 PM
  • 109,885 POSTS
Here is a how to video and directions for checking fuel pressure. You will need a gauge, but most parts stores will lend or rent them to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Here are the directions for checking for vacuum leaks. Again, you will need a gauge. Check the parts stores to see which will lend or rent it to you.
https://www.2carpros.com/dia/test_engine_vacuum.htm
Thursday, June 17th, 2010 AT 12:11 AM
