Hello lgreg
Worn and weak fuel pump, obstructed fuel line, low voltage at the pump can also prevent it from running fast enough to generate adequate fuel flow. The pump's supply voltage should be within half a volt of normal system voltage.
SPONSORED LINKS
Sunday, March 28th, 2010 AT 7:43 PM
