2000 Ford Ranger IDLING VERY ROUGH
AMILYNX
  • 2000 FORD RANGER
  • 6 CYL
  • 142,000 MILES
HI. MY HUSBAND HAS A 2000 FOR RANGER AND IS HAVING PROBLEMS WITH IT IDLING VERY ROUGH. NO CHECK ENGINE LIGHT COMES ON. WE'VE CHANGED THE FUEL FILTER, THE PCV VALVE, THE SPARK PLUG AND WIRES AND NOTHING SEEMS TO HELP. ANY IDEAS?
Tuesday, December 9th, 2008 AT 9:04 AM
RENAUDTN
  • 636 POSTS
-Check your fuel pressure
-Make sure there's no vacuum leak
-Check your egr valve (make sure it is not stuck open)
-Check compression
If the truck runs fine while driving, suspect a vacuum leak or a bad egr first.
Tuesday, December 9th, 2008 AT 10:45 AM
AMILYNX
It's not turning on the check engine light to throw a code for anything
Tuesday, December 9th, 2008 AT 11:07 AM
RENAUDTN
  • 636 POSTS
There are many things that can go wrong with a car without turning on the check engine light.
By the way, even if it is not on, you may have codes in your computer. (Pending codes, history codes).
So check that out just in case.
Tuesday, December 9th, 2008 AT 1:56 PM
