2000 Ford Ranger rack and pinion
2000 FORD RANGER
SLY001
Steering problem
2000 Ford Ranger 6 cyl Four Wheel Drive Automatic 73k miles
hi guys, when turning the wheels, while its running, i get a grinding/ metal on metal noise. no fluid loss. is there a way to check if there is a blockage or internal leak on the rack?
Jan 30, 2008 at 12:42 AM
JSMWRENCH
Hi there.
I work at the plant that manufactures the rack and pinion for Ford Rangers. Are you sure the sound is coming from the rack? As far as internal leakage goes, if you had internal leakage, it would feel as though you didn't have hydraulic assist. If the sound is coming from the rack area, then I would suggest looking at the tie rods, ball joints, or other steering linkage. If the sound is coming from the engine compartment, you may have a power steering pump going bad. Anyway, I hope this info helps.
Ron.
Mar 30, 2008 at 6:56 PM
