HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Steering
Rack and Pinion
Replace/Remove
1998 Ford Ranger
J A
MEMBER
1998 FORD RANGER
6 CYL
4WD
AUTOMATIC
136,000 MILES
Directions on how to change a rack and pinion boot
Tuesday, October 14th, 2008 AT 6:59 PM
BMRFIXIT
MECHANIC
Jack and support vehicle
remove tire
disconnect and remove outer tie rod end
remove the boot
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Wednesday, October 15th, 2008 AT 7:30 PM
Please
login
or
register
to post a reply.
Related Rack And Pinion Replace/Remove Content
Rack And Pinion - 2001 Ranger
Just Had My 2001 Xlt Ranger Serviced With Oil Change And Alignment. During The Process It Was Discovered That The Rack And Pinion Were Shot...
Asked by
beezerdds
1 ANSWER
2001
FORD RANGER
2000 Ford Ranger Rack And Pinion
Steering Problem 2000 Ford Ranger 6 Cyl Four Wheel Drive Automatic 73k Miles Hi Guys, When Turning The Wheels, While Its Running...
Asked by
sly001
1 ANSWER
2000
FORD RANGER
1998 Ford Ranger Power Steering Pump Noise
My Son Has A 1998 Ford Ranger And It Makes A Noise That Sounds Like There Is Low Fluid In The Power Steering Pump. This Niose Is So...
Asked by
clumpkin
1 ANSWER
1998
FORD RANGER
2003 Ford Ranger Electrical Problem In Steering...
When The Steering Column Is Adjusted Down, The Turn Signals And Brake Lights Will Not Work. When The Column Is Put Back Up They Work Fine....
Asked by
msafrit
1 ANSWER
2003
FORD RANGER
1999 Ford Ranger Power Steering Pump
Steering Problem 1999 Ford Ranger Two Wheel Drive Manual How Do I Get The Power Steering Pump Out Of The Ford Ranger 2.5 1999
Asked by
richntaz
1999
FORD RANGER
VIEW MORE
Power Steering Box Replacement
Steering Intermediate Shafts Replacement
Power Steering Pump Pulley Removal
