2000 Ford Ranger
RFLOOD18
  • 2000 FORD RANGER
  • 6 CYL
  • 53,000 MILES
I've recently had the engine replaced in my 2000 Ford Ranger. The plugs and wires were replace when the engine was installed. The replacement engine only had 50,000 miles on it, but I've had nothing but problems since it was installed. It is hard to start, idles rough, hard to start, isnt accelerating like it should, is running rich, and feels like it's going to stall when stopped. The check engine light came on and I took it to my mechanic he said the error code showed that the #4 spark plug needed to be replaced. The plug was burnt. The diaognostics and replacement plug cost $53.00 dollars. The car ran a little better (although not much) for about a week, and then the check engine light came on again. Now I'm having the same problems as before, I am going to change the burnt spark plug again, but I'm looking for a long term solution. Have you got any suggestions?L
Thursday, May 8th, 2008 AT 5:21 PM
  • 31,937 POSTS
Hi there,
thank you for the donation.
I would be looking at a faulty injector, it may be running lean in the Cyl and that will make it run hotter and will burn out a plug. I would get all the injectors serviced first, check the rail pressure. Start there.
Mark (mhpautos)
Thursday, May 8th, 2008 AT 6:33 PM
