2002 Ford Ranger hard to start
TERMITER007
  • 2002 FORD RANGER
  • 6 CYL
  • 100,000 MILES
When I first start the engine it takes a while to fire off each and every time I start it. Will run fine after it starts. Is there a cold start valve or somrthing on this truck?
Sunday, January 10th, 2010 AT 3:15 PM
  • 110,055 POSTS
It sounds like you are loosing the fuel pressure prime. Here is a how to for checking pressure. PAy special attention to the fuel pressure drop off when you shut the key. It should hold pressure. If it drops, there is a leak somewhere.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Tuesday, January 12th, 2010 AT 8:28 AM
