2002 Ford Ranger Slow to Start
MIKEY_T9
2002 ford ranger was ahving problems starting, and it turned out to be a dead battery. But still with the new battery the truck may at times be slow to start, like three to four seconds. I had the altenator checked and its charging fine. Is this normal or could still be something wrong with the truck other that the battery i replaced?
Feb 22, 2006 at 5:12 AM
2CARPRO BOB
  • 45 POSTS
Make sure that the replacement battery is the proper amp size for your vehicle. Verify that the starter is in good condition by doing an amp draw.
Feb 22, 2006 at 12:18 PM
Suggested Repair
Confirm the replacement battery has the correct amp rating for the vehicle, and test the starter with an amp draw test to verify it is in good condition.
Conversation Summary
The owner of a 2002 Ford Ranger replaced a dead battery, but the truck is still sometimes slow to start, taking three to four seconds. The alternator was checked and is charging properly. The expert advises confirming the new battery is the correct amp size and verifying starter condition with an amp draw test.
