1998 Ford Ranger Power steering noise
1998 FORD RANGER
110,000 MILES • 4 CYL • 2WD • MANUAL
SURFDUDE
How do you flush and replace power steering fluid?
Jan 6, 2008 at 6:05 AM
2CARPRO JACK
  • 11,533 POSTS
It can get messy. I usualyy remove the return hose from the p/s pump and plug the nipple. Stick the hose in a bucket or container larger than the amount of fluid you will be using to flush.have someone start the engine with the resevoir full, it will drain out, as it does fill it up with fresh fluid. Dont let the pump run dry, it is bad for it.
Jan 9, 2008 at 11:30 PM
