1998 Ford Ranger engine problems
87,000 MILES • 4 CYL • 2WD • MANUAL
DANC15
engine physically shakes about 2 inches in either direction after being reved up a little. its smooth when you initially start it. noticable lack of power when accelerating. it has a popping noise when being reved up. occasionally backfires. i have changed 6 of the 8 plugs on the 4 cylinder engine (the other 2 look hard to get to i havnt tried em). initially went to az and they got me my error code which said it was 2nd cylinder i replaced both plugs and wires on 1 and 2, only the exhaust plugs on 3 and 4. The symptoms have pretty much changed the same, but the car seems to be a little more driveable now ( it wont die on me as much since i have been messin with it).
Feb 19, 2009 at 7:19 AM
BILLYMAC
  • 2,204 POSTS
hi dan you need to do a compression test on all 4 cylinders. if compression is ok you need to check injector pulsewidth with a scanner. if you have no comp on a cylinder remove valve cover check and make sure the rockers are all in place and that the cam lobes are all good. billymac
Feb 19, 2009 at 8:07 AM
