1998 Ford Ranger
CARDUMB08
  • 1998 FORD RANGER
  • 6 CYL
  • 109,000 MILES
I just had a coolant hose in my truck rupture, which caused coolant to go everywhere. I started my truck the other day and it has a hard time starting, and when it finally does it shakes and wobbles for about one minute. I thought maybe I had water in the oil, so I changed the oil, but it is still doing it. Not sure if it is the spark plugs or what. An answer would be a appreciated. Thanks
Sunday, November 2nd, 2008 AT 10:06 AM
BLACKOP555
  • 10,371 POSTS
Electrical compnents do not liek water, I tink you best bet is to take and dry off all the electrical connections and components.
Did the ignition module or coil get wet?
Sunday, November 2nd, 2008 AT 3:36 PM
CARDUMB08
I am not sure, but coolant sprayed everywhere when the valve thing broke. I dried off the spark plugs, and it has been long enough that most everything else should be dry by now.
Thursday, November 6th, 2008 AT 8:00 AM
BLACKOP555
  • 10,371 POSTS
If you got the coil wet and it fried it dont matter if it dried out or not it wont work no more.
Some connectors can get water in and it stay for a while messing with it.
Thursday, November 6th, 2008 AT 8:59 PM
