Wednesday, March 26th, 2008 AT 6:13 PM
I've been having a problem with the automatic transmission shifting. It will jerk real hard into 2nd gear and then again into 4th gear. The engine will rev up high and then the transmission slams into gear. Lifting off of the gas pedal does not help with the problem. I was told by a mechanic that replacing the transmission filter and fluid that it would fix this problem. However, the problem continues. I had no metal flacks in the transmission pan or filter when changed, the fluid level has always been good and this just started about a month ago. I tried putting Lucas Transmission Fix in it, but that did absolutely nothing. Any idea what the problem could be besides the transmission going out in it? Thanks!
