1988 Ford Ranger Automatic transmission fluid replacement
TROYBUELL
  • 1988 FORD RANGER
I have a 1988 ford ranger (6cyl, 2wd) and would like to drain and replace all the transimission fluid. The guy at the auto parts store told me I could drop the pan, start the car, put it in drive, and let the pump pump all the fluid out. I tried this but it doesn't seem to work that way. Any Ideas?
Saturday, January 14th, 2006 AT 3:35 PM
WANZER2
  • 11 POSTS
You will never get all the fluid out. Where is the auto parts place so I don't go there, trying to fry your transmission?
Sunday, January 15th, 2006 AT 6:48 AM
DUDE
  • 50 POSTS
On most automatics you drop the pan, change the filter, put on a new gasket put back together, fill to the correct level when hot & in park using the right type of fluid and you should be ready to go :D
Monday, January 16th, 2006 AT 2:13 PM
